O sole mio?Singing into PC is the easy one. When you say "how compatible they are", what are you needing to be compatible with?
It does matter, it uses RGB+IR and can tell distance from the camera. Not sure how far away until it doesn't work, but definitely not at the level of 10m, usually the max is 8 feet / around 2m. Think this probably does have to do with when you set it up, how large face was in frame, etc.It doesn't matter if they are 2 meters or 10 meters away from you.
MS fully supports as of a year ago on consumer accounts, think business side was a bit earlier as I remember using them for some internal systems in 2023, though could we got "early" access/test as were a very large client of MS and good chance asked them for it.Google supports pass keys these days... apple too I think... I don't know about MS
I've use github on my linux pc I never know you could use it on an android device.It does matter, it uses RGB+IR and can tell distance from the camera. Not sure how far away until it doesn't work, but definitely not at the level of 10m, usually the max is 8 feet / around 2m. Think this probably does have to do with when you set it up, how large face was in frame, etc.
I've also been thinking of getting a fingerprint one, make it easier to sign in to password manager more often / maybe make it each time since I don't log into stuff that often.
You can try using an old android phone: https://github.com/MeisApps/pcbu-desktop / https://www.xda-developers.com/unlock-windows-pc-fingerprint-scanner-android/
Was thinking about doing this, but think if I do, will probably be get actual dedicated device
Except when your kids can get into the most secure device in the planet :’(Aaah it's good to be in land.
Wouldn't it be nice to use the finger print sensor for my password manager in the browser... unfortunately that's a fail on Apple.
Oh, definitely an issue with the Bitwarden software but hard to believe it's nothing to do with Apple. I don't want to switch to apple keychain though - that would make life difficult for my Linux and Windows boxes.
Linux?
Same price as similar specced Windows and Android devices. They're great value for money nowadays. This is not 20 years ago.I find Apple way over priced for what you are getting
But to OP, I use fingerprint sensor on my PC and obviously my kids have never managed to get past that.
