First Investment in Solar
Vleisie
On top of the current load shedding, our area has been subjected to frequent power outages due to a troublesome substation and cable theft. I've finally decided to take the plunge and invest in solar power to achieve the following:
1. Continue to run critical components throughout power cuts / load shedding
2. Reduce the reliance on the grid as much as possible to save on electricity costs
Our average daily usage is around 18-22kWh depending on the season. We've also got a gas stove and solar geyser so our peak usage should not be too great. What seems to be the best solution is to go for a Hybrid inverter coupled with a couple of batteries and PV panels.
I've contacted a company that proposed the following solution:
* Sunsynk 8kW Hybrid Inverter
* 2x Pylontech US3000 3.5kWh batteries
* 12x Canadian Solar 365W Poly PV panels
I'm very new to solar energy solutions so please excuse my ignorance with the below questions:
1. Does the above seem like an appropriate solution?
2. How does the Sunsynk 8kW inverter compare to similarly priced inverters such as the Goodwe ES 4.6kW Hybrid Inverter and the Alpha-ESS Smile5?
3. How much would the installation of such a system cost and do you have any recommendations for installers in the Centurion/Midrand area?
4. Has anyone dealt with solar-shop.co.za before and what was your experience with them?
