Fix It Pro - reviews
d7e7r7
So I came back to my car a few days ago to find a scratch along the passenger side runs along both doors. :cry: It's not very deep so doubt it's a deliberate keying but more as a result of someone squeezing past my car to walk between it and another car.
I tried polishing it out and it certainly made it better but if you look closely you can definitely still see there is a scratch there :(
Has anyone tried this product from Homemark? It's only R150 so I might give it a try if other people here have tried it and have good reviews of it...
Link: http://www.homemark.co.za/product/house--home/fix-it-pro-
I've used it , sort of works but not like in the advert, if you have one of those china mart / china city places go there and get it , costs about R20 , its exactly the same. Homemark rips of people as they buy the same stuff from china
Ok thanks :)
How old is your car? Might be worthwhile having the entire car buffed & glazed.
Fix It Pro - Looks "quite good" at first but after a bit of rain or a wash or 2 you are back where you were.
It works quite well on surface scratches, it just replaces the clear cover over that area. Used in before and was quite impressed, but sure you can get different product for much cheaper that will do the same thing, as said earlier.
Doesn't really work, tried it and all it did was leave blobs no matter how I applied it.
Luckily it washes off amd you are back to square one
