Do you guys have any advice on how to fix a water damaged samsung d900. It doesn't turn on at all. I'll try anything. I've already opened it now I just need to know if there's anything I can do. . .
according to the article you must take out the battery and sim then suck the water out (vacuum cleaner) and also keep in a bowl of dry rice for the evening. the whole phonwe and battery must be submerged in the rice if you dont want that dust from the rice all over you can use that silica gel also. its a long article and i cannot type fast to get the whole story across for you. sorry man.
