FNB How can I Increase or decrease Cheque card ATM and POS Limits?
airborne
Looked all over the FNB app and online banking, f0ked if I can find where to change the debit card limits for till swipes and atm withdrawls, I adjusted it a while back so the functionality is there somewhere.
On online banking I clicked on manage cards and there was only the option to change the pin not limits.
Anyone that can direct me where to look before I waste time/airtime phoning their call center?
Also remember seeing limits - it may have been changed to going into the branch as a secure thing.
But you can send message via Internet Banking or use the App to call in free of call charge but data rates apply.
G
Just go to "online banking settings" it wil open all the options you want.
They changed it recently iirc you click on accounts then settings then there should be a daily limit thingy, my internet is buggered at the moment otherwise i wouldve double checked
G
Thanks forgot about that direct call option on the app, called them now and the adjusting of card limits online functionality has been temporarily removed due some issue with it.
So I'm not going crazy after all, wish that had been mentioned on the website, bloodly looked forever.
Only way to adjust them at this time is in branch of by phoning in
