Hi guys, I have a Corsa bakkie. I have Osram nightbreaker+ bulbs on it. Brights are good enough but I added Hella 500FFs, dims are a bit weak though, they only light up the area close to the car so am looking to augment them with some mini driving lamps. I got two pairs of yellow and clear lamps. Which would be a better setup, having both sets connected to the dims and each pair with its own relay or connecting them like I did with my 500 ie having their own circuit and switch, drawing power directly from the battery. If I go with the former would I need a higher rated fuse and would a bigger battery help. 628 to 630. Btw which work better as foglights, clear or yellow lights ?
