It is. I'm still very happy with mine!All in all the Focus is supposed to be quite a solid car.
On the test drive go over a speed bump at the required speed and listen very carefully for any "knocking" sound from the rear suspension. It is not the shock absorbers!!
Thanks, will follow up!Trailing arm or sway bar bushings?
After your post I went and checked the UK Ford forums. You could be on to something!Lol, no I don't have a clue, actually asking you!
How's the rear tyre wear by the way?
