ford Ikon Radio code
Jet-Fighter7700
Somewhere Different
Hi Guys
searched around, and nowhere is it simple.
Im trying to unlock a ford Ikon radio, the 6000 CD version
replaced a battery and now it asks for a code.
went to Ford dealer, but nothing is ever easy at a dealer, says must disassemble the radio and confirm who owns the car and then we can find the Code for you.
is there a simpler way? got the VIN number shouldn't there be a database with what the radio serial number is online somewhere?
Or is this system expected to generate Money for Ford anywhere in the world.
If it has a Blaupunkt (Ford Branded) Radio, then you can dowload a Blaupunk Code generator. You input the radio serial number and it gives you two possible codes.
dunno if this is legit but i found this
needs the serial number, not sure if for that the radio needs to come out first.
also think it costs $$$
makes sense to have the serial number as a code needs to be generated... i think
EDIT: The fastest one is by turning the stereo unit ON and pressing 1 and 6 buttons for a few seconds.
So not sure if this will help anybody or I'm quoting the wrong version of radio here
Tried the 1,6 hold down code, didn't help me
This is the radio in question
Any other way of finding out the serial number?
Tried carcat.org to look it up
No luck there.
Is my only option to disassemble the radio and look at what the code is?IMG_20191001_094338.jpeg
