Formatting a Flash Drive
Drifter
Vereeniging
Got a brand new 8GB Flash Drive. Want to format it NTFS, but when I right click, format, I ony get FAT32 or
ex-FAT as options?
What am I screwing up?
a.) Tell us what brand it is & what o/s you're using, or
b.) It's faulty
Using XP, one of those company barnded drives, cant see what brand it is, properties just list it as Generic drive
Use the tool diskpart, just be careful you choose the flash drive and not one of your main drives.
SD Card formatter - does flash drives as well, it'll fix anything.
open MSDOS
change to directory of disk using 'cd' , so if disk is named z type cd z:
format z: /fs:NTFS
1. Insert the USB flash drive into the USB port.
2. Click Start, type devmgmt.msc in the Search textbox and press Enter.
3. Find Disk Drives and expand it.
4. Find the USB flash drive you want to format, and double-click it. It opens the Properties dialog box.
5. Click Policies tab.
6. By default, the Optimize for quick removal option selected, switch it to Optimize for performance and then pressOK.
7. Now open Computer. Right click on the USB Flash Drive and select Format. The Format dialog box now appears.
8. Select NTFS in the File System field.
9. Press Start and wait while the process will be completed.
10. Now your USB Flash Drive is formatted with NTFS format.
-Microsoft
I use this sequence to format flash drives as FAT32 for my *NIX, etcetera boot devices. To do NTFS, you need only change the fs=fat32 to fs=ntfs. Oh, and you can safely ignore the active command.
