Frame Error rates
Stõrmza
Hi there.
I am using a 2MB Modem, this evening iBurst is not usable at all for anything that requires any from of persistent connection.
Doing a simple ping to google.co.za here this is what I am seeing
Reply from 197.80.128.34: bytes=32 time=260ms TTL=56
Request timed out.
Reply from 197.80.128.34: bytes=32 time=76ms TTL=56
Request timed out.
Request timed out.
Reply from 197.80.128.34: bytes=32 time=105ms TTL=56
Reply from 197.80.128.34: bytes=32 time=87ms TTL=56
Request timed out.
Reply from 197.80.128.34: bytes=32 time=46ms TTL=56
Request timed out.
Reply from 197.80.128.34: bytes=32 time=201ms TTL=56
I have checked my modem and I am on 100% Signal but since late this afternoon the Frame Error rate is just jumping around from 0.1% to 15% I attribute all the time outs to this. This has never happened before even when its storming and overcast at the moment it's overcast but not anything extreme.
Changing MTU has no effect on this I've rebooted my modem etc.
Its connecting to BSCC 19 (Which it always does)
*Update 1*
Doing a speedtest I am able to get 1.7Mbps download however all speed test sites including MYbb and speedtest.net fail on upload test.
Any ideas if this is my side or just poor performance at the moment or issue with the tower?
Thanks in advance
Managed to sort the issue out....
Unplug iBurst
Plug in iPhone
Uselesssssssssssssssssssssssssssssssssssssssssssssssssssssss
*This post was made after having to spend money on a data bundle on my phone so excuse the hatred*
So this morning I was connecting to Aligned BSCC 20 not 19 anymore. JUst got back from work and its connected to 19 again but its really fast so Thanks to whoever fixed it. !!
Last Result:
Download Speed: 1987 kbps (248.4 KB/sec transfer rate)
Upload Speed: 386 kbps (48.3 KB/sec transfer rate)
Latency: 115 ms
Tue Dec 04 2012 16:08:35 GMT+0200 (South Africa Standard Time)
Well its still working really well so thanks.
Test conducted on Tue Dec 11 2012 16:53:32 GMT+0200 (South Africa Standard Time)
Download Speed: 1266 kbps (158.3 KB/sec transfer rate)
Upload Speed: 431 kbps (53.9 KB/sec transfer rate)
Latency: 138 ms
