Freelancer for Odoo required
hilrap
Hi there,
I'm looking for a freelancer able to support Odoo ERP. You should be able to:
- Setup Odoo Enterprise on cloud server
- Implement a few customizations
- Provide long term support
If you're interested, please inbox with your hourly rates.
Hi!
I’ve worked with Odoo ERP for quite some time, and I understand how crucial it is to have the right support for setup and ongoing maintenance. Setting up Odoo Enterprise on a cloud server, implementing customizations, and providing long-term support is essential for ensuring everything runs smoothly.
It’s important to find a freelancer with experience in cloud server setups and Odoo-specific customizations. I’d recommend ensuring they have good familiarity with the specific modules you’re using, as Odoo can be quite flexible but also a bit complex depending on your business needs.
Good luck with your search! Let me know if you need any tips on what to look for in a good Odoo freelancer or how to set up a proper support plan.
ChatGPT has entered the chat.
Hi there,
Hi Hilrap,
I’d recommend you reach out to these guys [email protected].
They do everything related to ERPNext though - not Odoo. But I know of someone who recently went with them and is quite chuffed.
Looking at their web site I'd recommend you don't reach out to them.
Buys domain...
Proceeds to use a @gmail.com address.
In this day and age... get the basics right...
Use the domain you've already purchased for your email - it's a big red flag not to.
