freelander 2 door rubber
Baggins
Any suggestions where to source a used inner door rubber for Freelander 2?
Part number LR001630.
R2500 new from dealer and none used in PE.
One dreamer offered me a damaged one for R675!
I really only need 1 metre to replace a damaged section.
You can also try Pro Auto Rubber, they sometimes stock automotive rubbers or have the profile to make them. They are based in Gauteng though.
Thanks. They do list a similar one - but out of stock.
Thank you Steinbach Auto!
Eventually I rang these guys who had done work on our Freelander and surprise, surprise - they have a Freelander 2 for wrecking and gave me a bit of door rubber. If anyone wants the metre I have left over, you can have it.
shame we dont have u-pull it places in SA, for things like this,
as its an incredibly niche part to try find,
tried the other day to find cluster globes and its rarer than hens teeth.
