The_Unbeliever
Hi there
On what % setting are your freezer operating on?
There have to be a sweet spot where you can balance electricity consumption with the coldness of your freezer. Too cold, and you waste electricity, too warm, and your food doesn't freeze properly.
The one chest freezer of ours seems to be running 24x7 atm, and I don't think it is correct - it just gobbles electricity. It should cool the insides down enough for stuff to be frozen and then stop, not just keep on running in an effort to freeze everything close to absolute zero.
Let's hear it from you guys.
I will check out on our freezers tonight and post the make, model and freezer temperature settings, so we can start comparing. (and hopefully save a bit more electricity).
Regards
Libs
Regards
Libs
