Fsx HELP plzzz...
scorpio007
Pretoria
Hi all please help im trying to play fsx multi...i got ip and port bt now error cannot connect to host...why? any1 help or have defferent ips? :confused:
Did you engage the multi port flip switch? the host wont accept port bt unless you have.
Don't confuse the guy.
All you have to do is try a few different ports. Multiply the port by two, and divide it by two, if neither of those work, then just try every port inbetween.
So what exactly is bt multiplied by 2? :)
