That is ping. Your timing is probably too advanced and fuel is pre igniting. Loss of power would also ensue.
Shouldn't be a problem with a fuel injected engine, which I'm assuming it is.
Most primitive fuel injections still run timing off an analogue controller from a vacuum sensor...
Of course it could be.
Back to a dealer, stat. Detonation can really ruin your engine.
I stand corrected.
I was under the impression that pretty much any modern car would have a knock sensor and therefore be able to adjust ignition timing as needed.
HI Guys, thanks for the inputs. Turned out moving from a Diesel car to a pretrol car i had high expetations for the petro sound. I expected it to be way queer than the diese. I took it in this morning and the guy told me that thats a norma sound.
Why am I the first one to ask how the OP can afford a car when he cannot spell or put a proper sentence together??
