Galaxy Note 2 root help
ahoudet
Fourways, JHB
I rooted my Note 2 and installed CWM 6 and tried installing DN3. The phone is now on a boot loop (goes to the Galaxy Note 2 logo while booting and turns off and continues the cycle). I can still get into download mode but not into recovery anymore. When trying to get to recovery. It shows the version of CWM on the bottom for a second and then turns off and continues the boot loop. The phone is still visible via Odin through download mode. I tried reflashing CWM but it still doesn't work...
You may have to flash the original Note II firmware as a last resort
Flashed the stock rom - That fixed my phone :) I then reinstalled DN3 using a slightly different method and that works great :)
Only issue now is that wifi never worked so I installed the new bootloader... Now wifi turns on but signal is low. When I go to the router, signal is full and when I click connect, it says not in range for a few seconds and then shows the full bars again but doesn't connect :(
I have exactly the same problem.... So I flashed the bootloader in odin and wifi switched on but did not want to connect. So I booted into recovery and wiped cache, delvik cache and factory reset.
Rebooted and now the wifi is working....
Did that but never helped... Reinstalled the ROM and it works now :) Loving DN3 so much:love:
Its pretty amazing hey... I actually put my iphone 5 back in its box after installing DN3 on my note 2. Using it now. Pretty damn cool.
Had an iPhone 5, just can't use a phone with such a "small" screen anymore:D
Yeah the screen is not the problem its the os I find a bit limiting.... It does not allow apps to run in the background meaning if you download files with apps cause you can't just download a file once the screen goes of the phone sleeps and stops the download.
Can't send file via bluetooth you download including music and video's. Can't really just set a music file to your ringtone maybe with some workaround it can be done but not a supported feature.
Having both a android and ios device I like both but feel like I really like the flexability of android more...
