Galaxy S5 Battery drain
Rickster
EVGA Fanatic
Joe'berg
So on my moms new S5, the battery is draining quite fast after we setup email. Here are some screenshots, please advise.
+1. I get about a day with moderate usage. All the fancy eye sensors etc turned off.
The Exchange services email apps are absolutely killing her battery, it's crazy.
Is it your mom's work email she is running on the phone?
If not, I would suggest running the mail account through Gmail or Hotmail, which will give it push capability.
The problem with the mail app is that is will connect every 5/10/15 mins (you can change it to longer intervals) to her mailbox to check if there's new email, which will drain any battery fast.
Yes its her work emails that are hooked up to the exchange server, i think the settings are set to "push", should i change that?
+1 Set it to push the emails through so it doesn't continuously check for mails and use cpu.
The problem is Exchange. It doesn't seem to work properly on Kitkat.
Here is a possible solution I have found :
1. Log into OWA.
2. Go to mobile devices. (On my account every phone I ever had connected to exhange was listed.)
3. Delete all of them. (Including the one you have now.)
On your phone :
4. Force stop
5. Clear data and cache
6. Delete account.
7. Restart
8. Re-add exchange services.
Good luck!!
1. Log into OWA.
On your phone :
4. Force stop
6. Delete account.
7. Restart
Good luck!!
Whats that?
Whats that?
Outlook Web Access
*For when your mom is not connected on the Exchange server, she can still access her mail via a web interface.
Normally owa.mycompany.co.za or mail.mycompany.co.za, etc.
Outlook Web Access
Ok this doesnt work because her company uses Exchange ActiveSync.
What can she do now?
Yeah they should have web portal for exchange
Here are some more examples
https://mymail.mycompany.co.za or https://mail.mycompany.co.za/owa
Check the exchange server address you use on the phone to setup the account and use that when trying to access web portal
https://(serveraddressfromphone)
or just ask your mom to find out from the IT guys at work how to access her emails from a website, they should give her the address.
To find mobile device settings:
1: Click Options (Right Top corner)
2: See all Options
3: Phone (Should bring up mobile devices)
2: See all Options
it looks like its http://oma.debeersgroup.com/
But it wont access that URL.
I mean look at this sh*t, every time I put the Wi-Fi on it constantly downloads data.
