Garmin Mobile XT for Tytn 2
Does anyone know if this is available and if so. Is there a version like the one for the N95 on this forum that I can get somewhere to try before I buy?
I'm sure it's the same thing, just different software... check on www.garmin.co.za
Here we go:
http://www.garmin.co.za/prod_detail.php?productid=167&categoryid=3&subcategoryid=15
Garmin Mobile XT. It's the latest innovation in phone technology.
Add wireless navigation to your Bluetooth-enabled laptop, smartphone, Pocket PC or PDA with Garmin Mobile™ 10 — a GPS and Bluetooth® wireless package that includes a portable receiver along with navigation and map software.
Navigate with Ease
Garmin Mobile 10 combines all the software you need to navigate in one application: Garmin Mobile XT with Garmap Southern Africa detailed street maps, including a hefty points of interest database. Simply download included maps and navigation software to a data card for your mobile device or insert the CD into your laptop to put navigation at your fingertips. Easily look up addresses and services and receive voice-prompted turn-by-turn directions to the front door. With saved routes and tracks, automatic off-route recalculation plus more, you'll never ask for directions again.
And it comes fully equipped with the full range of Garmin GPS navigation solutions that include:
# Map displaying
# Knowing you current location
# Turn by turn navigation by voice guidance
# Calling from data
# Exchanging locations via messages
# Sending emergency messages
Take It With You
The included GPS 10x receiver combines a high-sensitivity GPS receiver with Bluetooth technology in a sleek design. Both portable and wearable, you can mount the GPS 10x in your car or clip it to your clothes for navigation by car or foot. This compact, lightweight receiver features a long battery life (up to 20 hours of use) and is perfect for mobile executives and professionals.
Perfect for mobie executives and sales professionals, Garmin Mobile 10X adds full-featured GPS navigation capabilities to your cell phone, laptop or PDA.
And best part is - no cables or plug-in receivers thanks to embedded Bluetooth wireless technology.
GARMIN MOBILE 10 Features:
* Receiver: High-sensitivity WAAS-capable GPS receiver by SiRF
* Unit dimensions: 4.2 x 7.7 x 1.8 cm
* Weight: 60 g
* Battery type: Rechargeable and removable lithium-ion
* Battery life: 22 hours (typical use)
* Power supply: 12-volt adapter cable
* Interfaces: Connects to laptop, Pocket PC, Palm or compatible smartphone with Bluetooth wireless technology (serial port profile)
* Voice prompts: yes
* 3D or 2D map view: yes (laptops excluded)
* Auto sort multiple destinations (provides most direct route): yes
* Auto re-route (fast off-route and detour recalculation): yes
* Choice of routes (faster time, shorter distance or offroad): yes
* Route avoidance (avoid highways, tolls etc.): yes
* Garmin Online™ services compatible: yes (smartphones only)
* PeerPoints™ (send and receive GPS position): yes (smartphones only)
yes it will work. i have the htc p3300. but try tomtom. much better i think
just download the garmin files from garmin and start looking for the maps
"yes it will work. i have the htc p3300. but try tomtom. much better i think
just download the garmin files from garmin and start looking for the maps"
Beri
Does it mean one could use TomTom software with Garmin maps?
