The_Traveller
- Aug 9, 2008
Need advice please.
I opened the gas tank and hear a gas leak.
swapped out tanks and same problem.
I bought a new regulator from Makro thinking that is the problem.
I am battling to get the new regulator into the hose. I got it in as much as i could and
clamped it very tight, opened the tank and there seems to be no leak.
I am however very unsure and don't want to take chances.
Do you guys think its OK this way or should i rather get it done properly ?
