ichocolate
- Oct 17, 2011
Hi, living in Kensington, i was told that most people are having luke warm or cold baths as their water is not being heated due to low water pressure.
The counselor has advised the communities that the pressure has been turned down.
If i open the tap, to me the water seems high... but i might be completely wrong?
My gas pilot light stays on and when i open the HOT tap i do hear a hissing sound like you normally would BUt i see no BIG flame coming on so that it heats the elements/pipes.
Not sure when the pressure is coming back to life again in Kensington.
Or maybe water pressure is not the issue.
Do you know of ways to work around this problem and is it going to be expensive?
I dont understand why so much pressure is needed for the geyser to operate.
As i said, i open the tap and water comes out pretty string , according my liking.
I am suspecting the geyser is fine but no idea why this is a pain.
Please suggest commend assist thanks
Iv'e just attached pictures to show you which type of Geyser i have.
note that it is currently off as there is no point in running the pilot light.
