Veroland
Hi
When I had my inverter installed (Deye) almost 2 months ago I asked them to keep my generator switch in place so I can charge the batteries from generator if needed. I have a a switch next my db box where I can switch between grid power and generator, and the power line to the inverter is installed after this switch, so I take it the generator power will show on the inverter as grid power.
I decided to run my generator for a bit today so that it does not just stand still for months on end and noticed the inverter does not pull any power from the generator.
When I switch to my generator is can see on my inverter that it is picking up the V, it show's 220V and 0.2A. Whereas on normal grid it shows around 223V 2.0A right now for instance. Also on normal grid the frequency is 49~51Hz but I when I run on generator it shows 0Hz on the inverter but on the generator's display it shows 52Hz.
Does anyone have an idea where to look before I contact the installers?
