Gentoo - need help
BucK
Midrand
Need help setting up iburst on gentoo.
adsl-setup and then adsl-connect, nothing.
adsl-connect = timeout waiting for PODO packets or something.
Network card should be fine, or ifconfig says so. kernel = 2.4
Please help!
hokay. first move to a distro with a 2.6 kernel - this has far better pppoe support. Also, a newer distribution will have easier-to-use connection setting configuration - I recommend fedora core 3.
I can spare you some bandwidth if you want to get the ISO's from me.
email me at [email protected]apetown, removing the names of major cities in the republic.
