newby_investor
PSA to everyone: Murphy is watching and taking notes.
So I replaced my asbestos roof at great expense earlier this year. It's new and shiny. But it's rather flat.
I probably should have used the opportunity to get a good look at the geyser while the roof was open, but I didn't, and now I'm stuck.
I've now got a geyser that's leaking, and it needs to be replaced. The inspector from the insurance kind of shrugged his shoulders. I'm not sure how to go about things now. The insurer seems to want to just pay me about R11k and make it my problem.
I figure that my options are:
- Pull open the roof again, probably at considerable expense.
- Pull out the ceiling (fortunately it's a smallish room so it should be doable) and replace the geyser that way.
- Something else, like an outside-mounted geyser, or one with solar, or something.
The guy told me that modern standards want something to stick up 30cm above the level of the geyser (pressure release or something?), and there's not enough space inside my flat roof to be able to do that. So even if I could stomach the cost of ripping open the roof or replacing the ceiling, I may not find a plumber that's willing to install the geyser anyway.
Has anyone been through this kind of thing before? My neighbours have a geyser hanging off the side of their house which I think looks ugly. In any case it wouldn't really be an option for me since my house has a different design to theirs which probably wouldn't be amenable to hanging a geyser on the side of the wall.
My current inclination is to go for something like this, where the geyser itself is outside and the 30cm clearance thing isn't an issue:
Not ideal, I know, the prevailing wisdom here is to rather dedicate the roof space to panels, but I'm in the situation where I may not have a choice.
