So I have a Geyserwise Max solar geyser installed. The one "issue" I've found is that in the afternoon the circulation pump runs often. The reason it's problematic for me is that each time it happens my monitor goes off and on for a second or two. Presumably due to the power surge, but my monitor also has a 10m HDMI cable running between the PC and monitor, so could be interference anywhere along the way (the geyser is almost directly above in the roof, and the power cable must run down the wall close by). Anyways, I want to increase the max temperatures to reduce the amount of times the pump runs, and wanted to find out what are safe temperatures to use (erring on conservative)?
Currently I have mine set as default: 55 / 45 / 46 (afternoon) / 55
Solar diff: 7 degrees
Thanks!
Thanks!
