GFX purchase help
LeroyHarr
Bristol, UK
Hello to everyone.
A little while ago I purchased an ATI sapphire HD 5570 GFX and was going good for a while. Played most games on med-high with decent fps.
Just a couple of weeks ago I purchased a new screen which is full HD and at the moment the GFX and screen seem to be getting on okay-ish. The GFX does not have an HDMI port but the monitor does. VGA is just not cutting it anymore.
I would like to stay with ATI as I have had problems with Nvidia before. I have about ÂŁ130-140 (R1400-1500) to spend and would like the best of the best within that price range.
My current pc specs are : AMD Phenom 2 x6 1090T BE. 4GB DDR 3 1600Mhz. Arctic 700 watt PSU. Asus Crosshair IV Formula mobo.
Any help would be greatly appreciated.
Thanks in Advance.
Hello to everyone.
Thanks in Advance.
Why not just use DVI?
6850 or 6870 will suit you fine.
:D but I see that there are a few different types... XFX, sapphire, Gigabyte is there much of a difference? Prices vary slightly. Also what is the power supply connection required for that card? thanks.
Your 5770 should using a 6pin pci-e connector and the 6850 should use the same.
Just get the sapphire. not always the cheapest but great warranty support.
I have a 4770, and it works beautifully with my Full HD Samsung 32" LCD running 1920 x 1080. Just use DVI to HDMI Cable/converter.
Just buy the cheapest one dude, although before you do just ensure the warranty is at least 2 years.
I would imagine you only need a good 450w or 550w to run it.
Its a 5570, doesn't need power cables. But yes I agree with sapphire.
@plbartie true I could do that but I am also just needing a new GFX. I WANT FULL HD GAMING! :whistle:
Thanks guys
Guys is the Gigabyte GV-N570OC-13I GTX570 PCI-E Desktop Graphics Card a good card?
Yes, the Gigabyte GTX 570 OC is an awesome card, but you'll need a case with enough space and decent cooling.
Bummer dude,
Case:
VGA card length: 270mm (with HDD cage)
VGA card length: 390mm (without HDD cage)
GeForce GTX 570
Card size: 280 mm x 128 mm x 40 mm
So it means removing the HDD cage on that case.
ahh crap did not look at that.....Thanks for helping ponder, really appreciate everything.
Will go look for a new one.
I will only have 1 HDD. Will that still work?
But I would like to go for SLI in a few months time
Thats a lot for a case...loll. I will look into it thanks m8
Yea but you spend money on it now, in 5 years that case will still be going. You could say 4k for a gpu that will be outdated this time next year is expensive as well :D. At least with a good case it will go the distance.
That is a depressing though on the GPU lol,
That case does look nice.
