Gigabyte 3D Glaxay Liquid Cooling
adamr
Fourways, Johannesburg
Its the retail box from rectron, good reviews for an entry level setup, it is new, never been opened, still sealed ... was looking at R1000 ... think it retails for R1300
I have no experience with WC,just alot of stuff Im always hearing on other forums...I think if you wanna suss out the WC scene then an entry level kit is fine,but I have definately heard a package kit is only as good as your best air cooling as far as temps are concerned.The general consensus is to go custom because is is cheaper and it blows package kits out of the water.
http://www.xtremesystems.org/forums/forumdisplay.php?f=70
^^^The mother of everything that is Extreme....which will contain everything you could possibly want to know...
That being said,summary:suss out-kit is Ok...Hope I have been of some help.
