Gigaset problem
wskanaan
Hi all....
I have this problem with my Gigaset se568: it stops sending a signal after some time. When I turn it off and on again it works... but after some time it stops again. I could not find any information about this even on Siemens' website.... Has anyone faced such a problem?
Thanks in advance
Ok, here's the product page:
http://gigaset.siemens.com/shc/0,19...geType%3Amanuals_imagePos%3A0,00.html#content
I don't see anything in the manual where you can access the router and configure it through a specified gateway?
I would suggest, if you can, to see in your paper based manual where the configuration gateway is, log in to the router and change the channel of the wireless.
You say it doesn't send signal, is this wireless signal? Try to use channel 6,9,11 or 13 in that order.
If all else fails, send Siemens a support request and ask them for help ;)
Best to link to your device in future, so people can help you more easily, without having to google on a Sunday afternoon ;)
