Slowmow
Am I the only one that did not get my mid month "Give-Away" Data this month?
They've stopped giving mid-month data for a long time and it only lasted for a few months.
+1 thats been been done away yonks ago
Midnight to Morning
Free data after hours
If you use the Internet from 12am to 8am, up to 90% of your data is free.
The amount of data that you get free is dependent on your package (see table below). Midnight to Morning is available on iBurst Wireless packages (excluding Wireless Start).
For example: If you are on a Wireless 5 package and download 1Gb after hours, 600Mb will be free and only 400Mb will count towards your data limit.
Package Discount Free data per 1Gb Max free data
Wireless 1 20% 200Mb 1.25Gb
Wireless 2 50% 500Mb 4Gb
Wireless 5 60% 600Mb 12.5Gb
Wireless 8 80% 800Mb 40Gb
Wireless 15 90% 900Mb 150Gb
Are you referring to this? Because I have not noticed that 90% free data?
http://www.iburst.co.za/neuvo.aspx?link=get_packages_wireless_mid2morn
That's a really old article. Since then, they've gone from the 2GB package at R199 p/m to 10GB* package at R199 p/m. The 2GB package was exactly that, you only could use 2GB. Then they came up with the idea that users tend to use all of their cap by mid-month, so they doubled your package mid-month (e.g. 2GB package would get 2GB extra mid-month, 4GB package would get 4GB extra mid-month, etc.). After some time, they increased the amount of data from 2GB to 10GB keeping the price exactly the same and they introduced higher packages. Again after some time, they introduced the midnight2morning scheme where you get the same amount of data as your package to use during 12am and 5am but if you don't use it all, it gets reset to 10GB (or whatever package the user is on) the next month. If you don't use all of the Anytime data, it gets carried over in to the next month.
Iburst should update their website then.
Also, the midnight to morning times, according to Iburst website, is from 12:00 to 08:00?
Could someone from Iburst please refer me to the correct web address?
