Gizzu GPS300 Charging
KarlPillay
Johannesburg
Hi,
I see the specs on the Gizzu GPS300 show as follows:
  • Charging Times:
    • AC Adapter: 18V/3A (6.5hrs)
    • DC Car Charger: 12V (9.5hrs)
    • DC Solar Panel: 60W (6.5hrs)
    • PD Port: 45W (7.5hrs)
    • AC Adapter + PD Port: 18V/3A + 45W (3.5hrs)
My question is, can I use my 65W laptop charger to charge this via the PD Port?
Is the PD Port on this device "smart" enough to only pull what it needs or is there a risk of damaging the power station?
Most Lithium cells will handle 0.5c 2hrs charging or lets say 0.25c 4hrs charging
You can charge batteries from two sources
Can this item charge from two sources doubt any manufacturer will say yea go for it
Even if it does work ie charge from both you have to wonder ,will it be able to dissipate the extra heat ?
What is the voltage the PD port designed to handle?
If it is the 19v the laptop charger will put out , i doubt it will charge faster , ie most charging ports behave like a buck converter ie they just take what you put in and throttle it to what it is designed to charge at unless it isn't and migic smoke escapes
ie kinda like putting 4500w panels on a 4000w controller you never get more than 4000w
Jip definitely. :)
Thank you.
I see a lot of comments around the voltage having to match but the laptop charger has the following rating so I'm a little concerned:
Max Power: 65W
Input: 100V-240V, 1.8A, 50-60Hz
Output: 20V - 3.25A, 15V-3A, 9V-2A, 5V-2A,
Connector: USB-C
Thank you.
Max Power: 65W
Connector: USB-C
I am not familiar with the gizzu
And wasn't aware of what the PD port is hence the remark
As far as i have it there is signaling via cable and the charger and device will find common ground
Normally the output of the charger doesn't matter
ie example you can power a laptop that requires 65w with a 180w charger , it will only pull what it needs the charger will run cooler though as it won't be working hard
The same may apply here you may no get faster charging using a higher wattage input
So yea i would go with tomtomtom , first charging session with dual charging i would just keep an eye on it and listen and smell anything odd i would go back to single charging
