NathanDrake
- Dec 2, 2022
Global Shutter—A First for Mirrorless
Sony has delivered the world's first full-frame global shutter mirrorless camera with the a9 III. The use of a global shutter provides a leap in performance over the rolling shutter technology used for decades. A global shutter provides a near instantaneous and simultaneous readout of all 24.6MP, eliminating skew and other artifacts that plagued rolling shutters. It also far surpasses mechanical shutter technology is every way, making the physical shutter unnecessary in the a9 III.Global shutters help ensure consistent and uniform exposure across the entire frame in all lighting conditions. Flash sync is possible at any shutter speed-even the maximum of 1/80,000 second. The simultaneous readout also prevents banding from certain light sources, such as fluorescent lighting. In a gym, outside, or with mixed artificial lighting the a9 III will handle it with ease.
Pre-Capture & Speed Boost—Never Miss a Moment
Along with the key technology delivered by the sensor, the a9 III offers features new features to unlock the camera's full potential.
- Pre-Capture: The a9 III can be configured to begin recording images to the buffer when the shutter button is half-pressed. Users can set this between 0.05-1.0 second. Upon pressing the shutter these images will be saved to the memory card.
- Speed Boost: Not every shoot calls for the a9 III's impressive max speed of 120 fps. With Speed Boost and the C5 button, which is conveniently placed near the grip on the front of the camera, users can instantly switch their camera from their usual continuous shooting frame rate to a faster one to make sure their next shot is just right. Photographers will be able to select various frame rates up to 120 fps.
Pro-Quality 4K Video
While video benefits greatly from the use of global shutter technology-rolling shutter and banding artifacts are completely eliminated-the a9 III boasts plenty of other video improvements over its predecessor worth talking about.
- The a9 III captures and downsamples the full 6K image area to produce high-quality UHD 4K video up to 60 fps. It can also record 4K up to 120 fps with no crop.
- Record 10-bit 4:2:2 internally using All-I encoding for maximum quality.
- Output 16-bit raw via the full-size HDMI port to a compatible external recorder.
- S-Log3, S-Cinetone, and other Picture Profiles are available for optimizing the image for your workflow and production environment.
Refined Body Design
With a new generation of Alpha-series cameras comes some slight tweaks and modifications designed to make the operation of the system more ergonomic. The a9 III features a handful of updates:
- Addition of C5 custom button to front of camera body.
- Continuous shooting mode dial can now be disabled and shooting speed can be adjusted in the menu.
- Enhanced grip and the shutter button has been slightly moved to provide a more ergonomic experience.
- Dual CFexpress Type A/SD card slots provide versatility, allowing users to use existing media or pick up the faster CFexpress options to take full advantage of the a9 III's increased speed.
- USB-C port now offers faster USB 3.2 Gen 2 speeds of up to 10 Gb/s.
- 3.2" 2.1m-dot 4-axis multi-angle touchscreen LCD-first seen on the a7R V. This screen has a wide color gamut covering the DCI-P3 space.
- 9.44m-dot 0.90x OLED electronic viewfinder with maximum refresh rate of 240 fps. The a9 III benefits from maximum quality viewing at up to 120 fps.
- Ethernet port for advanced networking and data transfer workflows.
- The optional VG-C5EM Vertical Grip is designed to match the updated ergonomics of the a9 III, including the new C5 button.
Future Firmware Updates
The Sony a9 III is going to get better with time and there are some details on what to expect in future firmware updates:
- The ability to shooting continuously at up to 120 fps when using the maximum shutter speed of 1/80,000 second.
- Workflow enhancements for IPTC metadata and FTP functions.
- Addition of C2PA technology from the Content Authenticity Initiative.
Sony Just Changed Photography Forever
Sony just changed photography forever by releasing the Sony a9 III, the world's first global shutter camera. Global Shutter—A First for Mirrorless Sony has delivered the world's first full-frame global shutter mirrorless camera with the a9 III. The use of a global shutter provides a leap in...
