Golf car charger question
upup
currently offline
Hi, the power drive club car battery charger got 2 circuit breakers. One need to push it in order to reset it. This is not the charger on /off switch. My question is, what are they for. They are not labelled. I downloaded a golf car manual and it just says "15 circuit breaker". Was wondering if it trips, what is wrong.
One was faulty and it would not charge, I bypass it and now it works.
Aaaand there goes your warrentee. There is a reason for the circuit breaker - it avoids high current, either if the battery is faulty, or external circuit is shorted. They are quite difficult to break.... so yeah.
I am currently on holiday at the sea and 3 chargers here had the same problem, all older than 3 years, all 3 operating less than 200 meters from the sea.
