Goodbye Aberration: Physicist Solves 2,000-Year-Old Optical Problem
ponder
Niflheimr
https://petapixel.com/2019/07/05/goodbye-aberration-physicist-solves-2000-year-old-optical-problem/
When you look through your viewfinder and things seem a little bit blurry or lacking definition, it’s probably because you are using an “el cheapo” lens. So you read reviews and buy a much more expensive lens, and what do you do next?
You don’t go out to learn about composition and lighting to make better pictures. No. If you are a conscious and professional photographer, you start pixel-peeping to rationalize your expensive purchase.
And what do you find then?
The problem is still there. Right there, in the corners. They’re soft. The center is OK, but the corners are still soft. So you read more reviews and buy a better lens.
Lather, rinse, repeat.
But it’s not the manufacturer’s fault, nor yours for not having enough money to buy a perfect lens. Blame Greek mathematician Diocles, who formulated the problem over two thousand years ago in his book Burning Mirrors.
99.9999% of the time that happens because I've knocked the diopter out of position.
