Nephew
It is slightly different for VM. If you want settings sent to you phone for VM, find the SIM applications on your phone. In there look for the menu to "Request settings". That should trigger the system to send you the settings.
If this explanation is not clear enough or you still have a problem, reply here and I will try and find out the details and sort you out.
