it seems to run lumion, u need a gaming card..the vram limits the possibility of high res renders
ive just done a bit more research now and found this.
Title: Lumion Team, I need a Specs check
Post by: maikoo25 on May 23, 2013, 05:09:25 pm
Hi, my name is Miguel. I work for PBK architects and we are considering buying your software. We currently have two sets of different computers.
The old ones are:
Windows 7
Intel core quad CPU Q9300
2.5 GHz
RAM: 8 GB
64-bit
graphics card: NVIDIA quadro FX 1700
The new ones:
Windows 7
Intel Xeon CPU E5-2603
3.5 GHz
RAM: 16 GB
graphics card: NVIDIA quadro 600
I installed Lumion free on one of the old computers and it could BARELY run it. it was way too laggy and when i tried to export a photo the graphics card crashed and i had to reboot the computer. We are considering buying a set of graphics cards to be able to run the program smoothly but we would like to know if they are going to work well with the computers that we have.
We are looking at the "GeForce GTX 660 Ti" and the "GeForce GTF 480", we would install them on the new computers as we expect them to perform a lot better. So my question is, do you think with those graphics cards we would be able to run your program smoothly?
We usually deal with models from sketchup and revit, and they may be somewhat heavy sometimes. We would like to be able to save animations and to just fly over the models in real time so that the client can choose where to look from.
Title: Re: Lumion Team, I need a Specs check
Post by: peterm on May 24, 2013, 03:37:28 am
Quote from: maikoo25 on May 23, 2013, 05:09:25 pm
Hi maikoo25
Please refer to the guide on hardware for Lumion. LUMION 3: Minimum hardware requirements (
http://lumion3d.com/forum/f-a-q/lumion-2-minimum-hardware-requirements/).
The Passmark: Videocard Benchmarks (
http://www.videocardbenchmark.net/high_end_gpus.html) web site provides the guide as to performance of GPU's.
As you would appreciate, we are not able to provide definitive recommendations about running Lumion with your different scenes.
The complexity of scenes, referred to in minimum requirements is important to take note of.
Quadro cards that you currently use are not supported for Lumion, although some users do use them and get by OK. It depends on the actual scene requirements.
GTX cards (or equally performing Radeons) provide the best GPU platform. Apart from the number of cores in the card, the more VRAM there is the better, as this allows for more or higher resolution textures.
In regard the 660Ti, it has a Passmark of 4663 and that is sufficiently above the passmark score guide for moderately complex scenes.
The GTX? 480 is still near top of the Passmark list at 4306, and I see there are still plenty available on eBay etc, however they only have 1 or 1.5GB and are now 'old' in regard support for real-time shaders.
Budgets are always a constraint, but sometimes it is worth spending some marginal extra $'s so that it helps in possible future projects. You may find that the 680 that supports 4GB (some 660's do also) will be a better medium term option. Of course, NVIDIA are now in process of releasing the next generation 700 series to follow on from the Titan.
There are some cases where CPU and other hardware can cause bottlenecks for the throughput needed for the GPU Windows 7 +, definitely as 64bit, lots of RAM and a fast CPU can all help. I have an old Q6600 which is noticeably causing problems and so is being replaced soon
Lumion v3 is more demanding on PC's due to features such as real-time GI, Reflection Planes, 3D Clouds, etc. Your scene descriptions do not sound too heavy, but by the time you add in the entourage, and then effects and try to run that in real-time as fly-through during client presentations, then I would suggest trying to go for as much bang for your $ as possible (and then some
