Graphics Card fan
wizdumb
now randburg
the otherday my motherboard and cpu blew, now i got a new dual core setup, but noticed when i installed my graphics card, i noticed that it got very. on more investigation, i found the fan on the card not working. i went around looking for one couldn't find a fan that small. where can i find a small fan like that
i have a nvidia 256mb 6600 graphics card.
Thats almost the same price as his card:eek:.. Not worth it imho
I think you need to take replacement value into consideration.
What I did with an old card was buy a 40/50 mm fan from an electronics shop for about R30 and glue it to the heatsink with Pratley Steel Weld.
Worked like a charm.
I meant the price of the cooler :D
thanks guys...
yeah saw the fans at take2, but i reckon thats what the card is worth almost.
i guess, i will try juggy's suggestion....
so after spending my whole sunday looking for the stupid small fan, i came home with nothing - couldn't find anything.
so i decided to try and see if my old intel cpu fan would work, i plugged in and it worked, but the fan is to big. so the question is how do i attach this fan, as i guess superglue wont do the job
