Grapic Problem HELP!!!!
DeadCore
Pretoria
i have a problem with my Nvidia Geforce 8600 GT,i was tinkering with the settings is the nvidia control panel to set up multible display (know it's spelled wrong) after using the option force TV detection it asked me to restart my PC wich i did after that PC was showing on TV and everything worked fine that was until i wanted to play some PC games:eek:
picture.php
picture.php
trust me its a whole lot worst then it looks,if anyone had this problem before think u could help me out?
I would uninstall the NVidia driver completely and reboot.
Then install the latest driver you have with the default settings and try to build up your settings from there.
I've never had to force it to do TV Detection, I found that if the TV is on and plugged into the card upon PC reboot it detects it fine :)
Problems, problems and more problems with damn Nvidia and Daul Setups... sounds all to familiar :rolleyes:
Try reinstall the driver.
nope non of those thing helped but i found out on the nvidia forum that my card burned itself out trying to run high settings,but since it's only 4 months old i can go get a new one cause this should not happen well thats what nvidia said.
