H. 265 dvr box need to setup port forwarding
101els
Can sum1 plz help setting it up so I can view it from my phone
I am using a net gear dgn2200 m router
Hi
Did u get sorted?
Send more details of your setup and I will try help.
I have a router with a 3G connection. I can access my DVR via iPhone.
I still haven't come ryt I am using a netgear dg2200m router and h. 264 dvr
Okay,
U will need a dyndns or no-ip account depending on what your router supports.
Then u will need to setup port forwarding on the net gear (let's call it port x )
You will need to assign a static IP address to your DVR and point port x to the static IP
You then configure dyndns on your router.
You will need some remote viewing software (this should come with your DVR)
I don't have a detail step by step instruction guide. The above are the basics to setting it up. Hope this helps.
