cr@zydude
Hi guys I need some help deciding on which half ton would be best. It would be used for daily drives to work and back, and about 2 trips per week for stocking up a shop.
I've looked around a bit and it seems the only current models are the Nissan NP 200 and Chevrolet Utility.
Slightly older/discontinued are the Ford Bantum, Fiat Strada and Opel/Chevrolet Corsa Utility.
These bakkies are all pretty similar, in price range and features. Are there any major issues with any of them? Which would you guys recommend? Also, they are all car based, so would I be correct in assuming that they'd be more car like to drive than a 1 ton bakkie?
