Hard drive problem
Project X
Hello All,
Well i have been having problems accessing my hard drives from my computer.
Whenever i click on my other hard drive ( doesn't have operating system ) from my computer, i cant get access to them, instead i get error message that
" Windows Cannot find 'rose.exe', select search from start to locate the file ".
I cannot access any of my drives from my computer but i can access through Windows Explorer.
I have updates my system with virus and spyware scans, and there is no thread and virus definition is updated.
i cant understand the problem..
Can anyone help me to solve the problem...
:confused:
Go through windows explorer, turn on hidden files and folders and delete the autorun file from each drive. U have got a touch of a virus.
mmm sounds very much like a virus. Have you run a virus scan on your machine? I know you said that it was updated, but have you actually done a scan on the system. From past experience I can tell you that even though your system is being updated on a regular basis, does not mean you cant have been infected by a virus.
My suggestion is do a manual update, then do a full system scan.
try going into safe mode and doing wat dabouncer said if you cant get into it normally
You have a virus. Specifically, the Setrox virus. Follow the link to find manual removal instructions.
To boot into safe mode, press the restart button on your computer. As soon as you do this, hold down the Ctrl key until you see a menu. Select Safe Mode and press enter. Once you are at a windows desktop, run your anti-virus and see if it can pick it up.
If not, follow these removal instructions, from the link above:
Trend Micro Virus Removal Instructions said:
MANUAL REMOVAL INSTRUCTIONS
Terminating the Malware Program
This procedure terminates the running malware process.
1. Open Windows Task Manager.
• On Windows 98 and ME, press
CTRL+ALT+DELETE
• On Windows NT, 2000, XP, and Server 2003, press
CTRL+SHIFT+ESC, then click the Processes tab.
2. In the list of running programs*, locate the process:
rose.exe
3. Select the malware process, then press either the End Task or the End Process button, depending on the version of Windows on your computer.
4. To check if the malware process has been terminated, close Task Manager, and then open it again.
5. Close Task Manager.
*NOTE: On computers running Windows 98 and ME, Windows Task Manager may not show certain processes. You can use a third party process viewer such as Process Explorer to terminate the malware process.
On computers running all Windows platforms, if the process you are looking for is not in the list displayed by Task Manager or Process Explorer, continue with the next solution procedure, noting additional instructions. If the malware process is in the list displayed by either Task Manager or Process Explorer, but you are unable to terminate it, restart your computer in safe mode.
Editing the Registry
This malware modifies the computer's registry. Users affected by this malware may need to modify or delete specific registry keys or entries. For detailed information regarding registry editing, please refer to the following articles from Microsoft:
1. HOW TO: Backup, Edit, and Restore the Registry in Windows 95, Windows 98, and Windows ME
2. HOW TO: Backup, Edit, and Restore the Registry in Windows NT 4.0
3. HOW TO: Backup, Edit, and Restore the Registry in Windows 2000
4. HOW TO: Back Up, Edit, and Restore the Registry in Windows XP and Server 2003
Removing Autostart Entry from the Registry
Removing an autostart entry from the registry prevents the malware from executing at startup.
If the registry entry below is not found, the malware may not have executed as of detection. If so, proceed to the succeeding solution set.
1. Open Registry Editor. Click Start>Run, type REGEDIT, then press Enter.
2. In the left panel, double-click the following:
HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>
Windows>CurrentVersion>Run
3. In the right panel, locate and delete the entry:
dll = "C:\system32\rose.exe"
4. Close Registry Editor.
Deleting the Malware Files
1. Right-click Start then click Search... or Find..., depending on the version of Windows you are running.
2. In the Named input box, type:
Autorun.inf
3. In the Look In drop-down list, select the drive that contains Windows, then press Enter.
4. Once located, select the file then press Delete.
5. Repeat Steps 2-4 for the following files:
* NTDETECT.COM
* run.reg
* systemdate.ini
* systemfile.com
Important Windows ME/XP Cleaning Instructions
Users running Windows ME and XP must disable System Restore to allow full scanning of infected computers.
Users running other Windows versions can proceed with the succeeding solution set(s).
CTRL :confused:
