Has my onboard sound gone?
Re83L
Cape Town - Northern Suburbs
Hi guys, I recently bought a new pc, and have been getting lots of problems with it (most of which was fix-able in the end :) )
Anyway, I have a partition with my old Windows XP on it and then a partition with Windows Vista...
I have just finished installing updates on Vista, and when I restarted, I had no sound, only "white noise" (lots of it, whenever sound was supposed to play)..
So : I thought it must've been the updates, so I re-installed Vista...
NO Change... :(
So I tried booting up in my old XP installation, still the same problem...
I live in Bloem, but bought my pc in Jhb, so I have to be certain that something's wrong before I send my pc up...
Is there any way of knowing whether my onboard sound is broken??
How would I know for sure?
(I went into my Control Panel=>System=>Device Manager , but found no ewrror there, everything seemed to be working fine???)
reinstall the drivers on xp and test it again. Uninstall it first though
Did so, still the same problem...
It's doing it on both of my OS's, even after uninstalling/re-installing my sound drivers...
And it's even doing so after re-installing my whole Vista OS..
If it helps, my MB is an ASUS M2NE-SLi
i'll be honest with you, now is your chance to move away from onboard sound and get yourself a soundblaster audigy
cheap about 250
you could try resetting your bios and see if that helps if not get the board swopped out
Yeah, have been thinking about getting myself a SoundBlaster for a while now...
The only problem is : Tomorrow night's my first AGASA Clan match (COD2) and I need sound... So tomorrow I'm gonna settle for anything I can find in Bloem...
But anyways, I'll have to get my board swopped around in any case, I just hope that my problem is indeed sound :)
