HI All
Does anyone have an HD and SD PVR decoder setup on extra view, where the decoders are located next to each other? I was wondering if you change channel on the HD 1 will the SD decoder also change?
I am concerned around this as the only way my house will work is if both are next to each other ( due to the old existing cabling system ). I would hate to keep pushing TV 1 on the SD decoder to one of the HD channel ranges .
thanks
thanks
