HD PVR + Explora Linking Possible for 3 people to view?
zainmw91
Hi,
I just wanted some advise is it possible to link HD pvr + explora but three people should be able to watch and change channels under one subscription please advise accordingly.
Regards
Zain
How many channels can you watch simultaneously on the explora? I know only one on the HD PVR.
As far as I know the only 3 channel combo is the SD Pvr coupled with the HD PVR... But the SD PVR is being phased out.
No. Your only option for three separate viewing channels is a SDPVR as a extrveiw but, Multichoice doesn't support them any more so when they go faulty you are screwed.
you would only be able to watch two channels and record two or three depending on which HD PVR you have.
i already have sdpvr + hd pvr and 3 people can view but i got the new explora so i wanted to link it with hd pvr so that 3 people can watch but i guess i have no choice but to change my setup sd pvr + explora to get it working
I have a HD PVR and SD dual-view PVR and is able to watch at 3 different TVs and change channels.
Only way that I know of to view at 3 different places and changing channels.
Then you are forced to use the SD-PVR for your use case.
With the HD-PVR you'll only get two vieving environments when paired with the Explora
