HD PVR remote and Sinotec
Luke7777
Menlo Park, Pretoria.. AH/OS 500/250
Can anyone confirm the the HD PVR remote works with the Sinotec 47 " please ? If it does, does it use 02911 as code ?
If the answer to both the questions is yes, then it would seem that the receiver thingy on my TV "broke" :(
Hmmm.. should set mine up... be one less remote for ppl to fscking put in strange places.....
Mine works on my 42" with that code. I assume you pushed the right arrow waiting for your screen to turn off?
So I did. Was a last ditch effort to put the blame on my Sinotec remote. Seems my TV is the culprit......and NOT the easiest of things to take back to Makro :D. Won't attempt it over festive season anyway. Will have to make do without PiP :(
What a mission for what is probably a 5 min repair job, Luke > Makro > Sinotec > Makro > Luke
I would call Sinotec and see if there isnt an easier solution
