upup
So as I understand it hdmi is both video and audio.
So say you got a dvd plaver HDMI out to tv and you have a amp, what do you do with the audio. amp not hdmi ports.
Also, this guy dvd use to play hdmi, then not any more.I looked and then put it on av again. move the cable to the pvr and their was pics, so the cable seems ok.
The dvd is blu ray machine. It did work.
personally I dont like the hdmi connector, pull out to easy.
