Hi good people,
I'm having issues with my OEM headunit. It receives power, there are beeps when you press buttons, the back lighting and screen power up but it never gets passed the toyota loading screen as in the picture.
The screen only works when the car is in reverse and the camera feed is active.
I've tried all the usual troubleshooting like disconnecting the battery, hard reseting headunit, checking the plugs and cables etc.
I'm still finding no success...
Is there anyway to bypass the headunit or force it to play a disc or read a USB or auxiliary cable.
Any help or suggestions would be highly appreciated even a temporary solution could work untill I replace the headunit.
