TheOracle
- Nov 5, 2010
I have created a Heat Pump vs Electric Geyser Calculator.
Every heat pump quote leans on a spec-sheet coefficient of performance measured on a warm test bench, not a Highveld morning in July, and none of them ask whether the tank you're buying can actually keep up with two teenagers showering back to back. The calculator sizes the swap first, the tank and recovery rate you actually need, then shows the running-cost payback next to the number you'll likely get quoted, and what closes the gap between them.
Anyone interested can have a look here:
southafricafacts.co.za
Heat Pump vs Electric Geyser Cost Calculator SA
How much a heat pump geyser costs installed in South Africa, what it saves a month vs your electric geyser, and how long until it pays back.
