Who is the local manufacturer, if you don't mind me asking? Please send links when you have a chance, much appreciated.I've been using a heatpump for hot water for more than a decade. Everything on the property is powered by solar pv. It works well.
The only issue I've had is from waterborne silt in the municipal supply. Sometimes it's really heavy and the town water is brown. About 5 years ago the hot water pump in the heatpump gummed up with silt and had to be replaced. Fitting a strainer in the cold water line fixed that, and the only hassle now is having to periodically clean the strainer.
There are several threads on MyBB discussing this topic. I'm on mobile now so regrettably not able to find and post links to those discussions.
I was an early adopter and so researched this thoroughly at the time. In the end I went with a locally designed and manufactured system - mainly to ensure proper local support if required - and have never regretted it.
What's suits me well is the heatpump works day and night, cloudy or not. I have hot water all the time, even after a month of heavily overcast weather.
It's the Enerflow made by MTech in Potch. They've been making very large commercial heatpump systems for many years, used in hotels, hostels, prisons, etc. The little Enerflow is/was their first machine for domestic/residential use.Who is the local manufacturer, if you don't mind me asking? Please send links when you have a chance, much appreciated.
So I currently have my home automation set set up to run the geyser's 4kw element when the water isn't hot enough and there's enough PV power. But I really do need to reduce the geyser's element to smaller or alternatively actually reinstall my heatpump (which I kept).
Why does your temp graph look so jittery?This is my 300l evacuated tube solar geyser's electricity usage for the current month (December, 0kWh) and last month (Nov, 31.3 kWh).
So yes, it works and it saves a ton of money.
Rainy day today, so temperature not really going up (as opposed to yesterday this time when it was trending upwards).
Especially when it costs R35000.I swapped out my 4Kw element for a 2kw element - geyser runs off the Solar now and then at night if it did not reach target temp.
Have considered a heat pump; but with the geyser on the solar, I don't see the need to get a heat pump now
R35000? Is it made out of platinum?I have this beast:
Costs R 35 000 (approx) to have it installed. It holds 270 litres.
This was my total usage for November:
Hope this info is helpful.
Ja they are expensive. To be honest I didn't buy it, I bought the property with an old heat pump (same design). Long story short the old one burst and insurance paid for a like for like replacement which was this thing. I love it though.R35000? Is it made out of platinum?
How much did it cost to install? Do you ever not have hot water, during winter perhaps?This is my 300l evacuated tube solar geyser's electricity usage for the current month (December, 0kWh) and last month (Nov, 31.3 kWh).
