Flanders
- Nov 20, 2003
As a complete noob and non sparky,
40amp should be fine, But, can the inverter safely charge lithiums?
I don’t know. That’s what I was hoping some clever person here could tell me before I go blowing things up.
Depends if inverter fan is tied to Temp, always on or charge state.
Problem is Lithium used V is still high enough to be "seen" as full on Lead acid. So could cause inverter to stay on float but consume and heat asif proper bulk cycle. Without a fan this can cause overheating.
So If you do not have dedicated type setting for Lithium on the inverter, I would use lowest Amp setting possible.
If fan is always on or based on Temp then Hubble Lithium can use 1c (ie: 100A)
What inverter is it? Is it the Mecer modified sine type?As far as I'm aware (I'll need to pay attention now) the fan is on while running. I'm not sure whether during charge or temp.
Then it's safe to assume that it's not intelligent, just stick to the lowest setting, 10A.It's called Invisimo-2000 (modified sinewave)
Thanks for the input, guys.
So 10A - what does this mean in practical terms? I'm an idiot with this stuff. Obviously longer recharge time but does that mean it wouldn't get to recharge during uptime on the average schedule? ie. in theory on a 120AH battery that a full charge would take 12 hours? I'm trying to determine whether I need to now look at a new inverter before running out and blowing the 15k on batteries.
