drew137
I am wanting to go out and get WoW and get involved! Is there one common box version for both PC and Mac or do I need to get a Mac version?
its the same box as the pc version, but you will need to download all the mac updates.
i run it on my macbook pro, and once you install it you will need to download the wotlk patch which is about 1.6gb +- disvantages, on your macbook you going to run it on lower settings than pc i would imagine, and the mac is gonna get extremely hot i suggest using smcfan control and pump it to the fullest. otherwise it its perfect.
Wicked link thanksThis should get you up to speed...
http://electronics.howstuffworks.com/world-of-warcraft.htm
Wicked link thanks![]()
drew if you dont mind not seeing outland which you wont for quiet sometime or you dont want to play a Blood elf or a draeni then you just need the first part of the game, which costs like 99R if you want to play a BElf then you need the burning crusade, realistically you wont get to 80 in a month if its your first time playing as you will enjoy content at a slower pace so you could get that in a few months even.
