MarmiteMonster
- May 15, 2023
If I get a solar system with 1 battery and later on decide I need another will i be able to add another 1 or will I need to buy 2 so that they are the same age.
Don't tell me you are still considering installing a lead acid battery.If I get a solar system with 1 battery and later on decide I need another will i be able to add another 1 or will I need to buy 2 so that they are the same age.
